Rear Quarter Panels from California. I prefer to sell as a Pair $400. $250 each if separated. Rear Quarters are SOLD
Each harvested beyond spot welds so new owner can drill out spot welds on backside to create their desired replacement part.
Minimal rust anywhere. Almost as pristine as a factory part.
No damage, a couple dings possible that can easily be massaged out.
Local Pickup Only.
Can deliver in Los Angeles area for gas money.
Click to view attachmentClick to view attachment
Right headlight eyebrow. a little rusty around rubber grommets. $10
door sill, not full length. Can be used for rust repairs instead of buying whole sill. $15
door sill triangle support bracket $20
Targa latch complete. plastic handle is cracked and glued. $50
Front fender well rear corners.
Harvest the repair pieces you need. Jack donuts too!
Driver side has rectangular section cut from bubble as shown in picture. $30 each
Driver side suspension consoles. Still on unibody box frame that only had flash rust inside. Harvest the pieces you need for rust repair, or I can for extra. These are not available aftermarket for driver's side. $100
I can harvest the parts you need/want and ship. $175 plus shipping.Click to view attachmentClick to view attachment
