smooth_eddy
Jul 10 2005, 12:23 PM
Is this spot ok to put a floor jack to lift the whole back end at once?
tat2dphreak
Jul 10 2005, 12:26 PM
if you are pointing to the engine bar, yes... go for it!
Allan
Jul 10 2005, 12:30 PM
I wish I could get my floor jack that far under the car. Life would be alot easier.....
SLITS
Jul 10 2005, 12:36 PM
So this was discussed in a thread not to long ago....us barbarians jack the backend up via the tranny housing. I use a floor jack and wooden block and place it where it doesn't catch the clutch roller assembly. Haven't broken tranny ears yet.
smooth_eddy
Jul 10 2005, 12:56 PM
QUOTE |
I wish I could get my floor jack that far under the car. Life would be alot easier..... |
Well in order for me to get there and operate the jack pump handle, I have to drive the car up on ramps first. Luckily I can do that. Thanks, Eddy
rick 918-S
Jun 28 2020, 07:39 AM
The engine bar is designed to support the weight of the engine not the other way around. It will bend. The other issue is the mounting pointa for the engine bar are not designed fir that kind of force. I made a cross bar that goes under the trailing arms at the axle end side.
Olympic 914
Jun 28 2020, 07:56 AM
Holy Necro-thread Batman....
mlindner
Jun 28 2020, 08:29 AM
I would borrow another jack, one on each side. Put a 2 x6 across on each side from the donut to the engine support mount. Jack both up at the same time. works great with no stress on car. Best, Mark
KELTY360
Jun 28 2020, 09:54 AM
QUOTE(SLITS @ Jul 10 2005, 10:36 AM)
It was always more fun to disagree with him but Slits knew his stuff. Miss that guy.
Frankvw
Jun 28 2020, 10:57 AM
@rick 918-S "
I made a cross bar that goes under the trailing arms at the axle end side."
Do you have a picture of that home-made tool ? Interesting to see !
Thanks !
rick 918-S
Jun 28 2020, 06:07 PM
No picture. I am moving soon. Maybe if I lay hands onc it while packing I can add a photo.
rgalla9146
Jun 29 2020, 06:01 AM
Lay two 16" 2 x 6s flat on the floor in front or behind the rear tires.
Drive or roll onto them. Need more clearance ? Add another length of 2 x 6 on
top of the first. Stagger them to ease the roll onto the second level.
Put the jack under the cast iron cross bar. You'll get plenty of lift with the jack there.
Use sturdy jackstands.
