QUOTE(bbrock @ Jun 28 2020, 02:47 PM)
Flex Seal is good stuff and I'm sure would work if you can get the foam clean enough to stick, but it lays down with a very heavy orange peel texture. For that reason, I'd be inclined to try Plasti Dip spray instead.
I went back and forth about the Plasti Dip Spray (some said don't use the spray as it will disintegrate the foam. In the end, I was worried either Plastic Dip or Flex Seal might just result in a bigger mess. Then I thought about a thin vinyl (too difficult to work with) or a trunk liner, but finally decided that a piece of felt (from Michael's) and a strong adhesive might be the safest bet. If I messed up, I could probably get it back off. Anyway, I'm happy with this result... Not too difficult. It's not like this is ever really visible, but at least it should halt the disintegration.
