I have 3 fans. 1 has all it's fins. 1 is missing one and has a bent one and the 3rd is missing 4 fins.
So I install the best one. It has the raised center with the plastic cap and requires allen head bolts to attach to the hub. So I got the fan attached to the hub on the crank. I can see that 2 of the fan shroud studs are hitting the fan, but the engine still rotates by hand.
So I got my fan housing and mounted it. Then attached the fan. It seems that the back of the fan is WEDGED against the inside of the shroud. Once the fan bolts are tightened I can't turn the engine by hand.
In case I was missing something, I checked AA. #3 is a SPACER. Is this the purpose of the spacer? To pull the fan out a bit.... Damn, just another part that could be somewhere in my stash. CRAP.
I seriously do not remember that part. Anyone have any pictures?
