Is it possible to get any seeping from the piston (plunger at the pedal) if one applies brake pressure beyond anything used while driving? I've been having caliper leaking issues so been pushing the pedal hard to test.
My guess is the MC should be bone dry, but just want to verify.
I have a spare 914Rubber MC with barbed supply lines and watched Ian's video (thanks Ian) and have a few questions for those that have done this.
1) Is it possible to do this with the gas tank installed? It appears yes, but don't want to discover this with brake fluid lines exposed.
2) Has anyone just unmounted the reservoir and left the supply lines attached? or do they have to be detached to get enough freedom to disassemble?
3) If the lines have to be detached, I'd like to replace the cloth braided tubes between the reservoir and plastic tubes. Does anyone have the specification for that tube?
4) In the video all the lines appeared empty. I plan to empty the reservoir with a turkey baster, but is there anyway to empty the plastic lines or just be ready when I disconnect them.
5) I can't push the reset button on the 914Rubber MC I have. It seems solid and not a button. Does there need to be brake pressure before the button can be pushed in?
