Driver174
Jul 2 2020, 06:58 PM
I really like the Panasport wheels, but they seem to be difficult to find. A call to a Panasport dealer didn't pan-out either. The VTO Classic 8 looks simular to my panaspot wheels.
Click to view attachment Click to view attachment
914e
Jul 2 2020, 10:50 PM
I have VTO wheels. I went with 16x7 and 195/55 Pilot Sport AS 3. So far I only about 80 feet on them so I have no idea how they are driving.
Luckily VTO had just moved to a location about 2 miles from my house. I was going to pick up a wheel to check clearances. As luck would have the owner Alex had a 205/50 mounted on the Classic 8 up in their old location and offered to bring it down. Good thing I took him up on his offer.
My passenger side rear was tight. After measuring it seemed that fender lip was about 1/2" closer to the inner structure. I was still prepaint so I pushed the fender lip out to match the other side. I might have been able to pull it off painted but who needs that stress. I then rolled the inner on both sides just to be safe. They had different wheel in a darker gun metal finish that I loved, so I had them finish the whole wheel in the darker color.
Click to view attachmentClick to view attachment
JamesM
Jul 3 2020, 02:05 AM
I like them... they weigh less than my last set of wheels...
Click to view attachmentRunning them on my flared car with 215/45/16s but they are really made for a narrow body car. ET35 so you in most cases you should be able to get a 205 to work without much fuss
gereed75
Jul 3 2020, 06:16 AM
I have several sets for my race car. They are very nice and very reasonably priced. Available in several styles and factory drilled to your bolt pattern. I get mine here
http://www.futofab.com/index.php?option=co...3&Itemid=74James, did your come with the optional levitation air in the rears?
Jul 3 2020, 06:53 AM
There's a set for sale on pelican. $800 4- 4 lug.
JamesM
Jul 3 2020, 10:30 AM
QUOTE(gereed75 @ Jul 3 2020, 04:16 AM)
No, i added that after the fact!
JamesM
Jul 3 2020, 10:37 AM
QUOTE(mepstein @ Jul 3 2020, 04:53 AM)
Not sure what their current pricing is but I got mine for less than that brand new with lugs and caps direct from VTO.
Driver174
Jul 3 2020, 10:55 AM
I can order them new for that price, and can specify exactly the offset needed. Toyo RR’s 205/50-15 fit perfect with 31mm offset. I mounted a Hoosier 205 on one of my Panasport wheels, but discovered they are slightly wider than Toyo’s. Hoping to tweak the offset slightly so Hoosier’s will fit.
mwyatt
Jul 3 2020, 11:18 AM
Anybody know the weight of a 15x7 or 16x7? Would like to eventually source wider wheels than the 5.5" Mahles I'm running on my 4-lug narrow bodied car, but some of the aftermarket options available in the past were heavy (18-20 lb range, compared with 5-lug Fuchs 7" Fuchs at around 15lbs)
Driver174
Jul 3 2020, 12:48 PM
VTO website says 15 x 7 Classic 8 wheels are 17.4 Lbs. They are heavier than Panasport wheels I believe
davesprinkle
Jul 3 2020, 06:15 PM
Do the lug bolt holes have the proper factory-style conical lug seat?
Freezin 914
Jul 3 2020, 06:26 PM
FYI, I have a brand new set of 16x7’s in the box. I would sell for $800 plus shipping.
jim_hoyland
Jul 3 2020, 06:35 PM
QUOTE(Freezin 914 @ Jul 3 2020, 05:26 PM)
That’s a great looking wheel
Do the 5 lugs fit the 914 ?
Freezin 914
Jul 3 2020, 06:44 PM
QUOTE(jim_hoyland @ Jul 3 2020, 07:35 PM)
These would fit 4 lug narrow body cars.
porschetub
Jul 3 2020, 07:02 PM
QUOTE(Driver174 @ Jul 4 2020, 06:48 AM)
Jeez that's heavy ,must be cast alloy ? ,nice looking wheel however.
914e
Jul 3 2020, 09:03 PM
QUOTE(jim_hoyland @ Jul 3 2020, 05:35 PM)
They have 5 lugs for the 911 and they do custom drilling and offsets.
windforfun
Jul 4 2020, 02:32 PM
Gorgeous wheels. I had very similar ones on a BMW 1600.
Driver174
Jul 24 2020, 09:24 PM
QUOTE(davesprinkle @ Jul 3 2020, 05:15 PM)
@mwyatt These VTO Classic are 15 x 7 with 38 mm offset and weigh 13.8 lbs.
bkrantz
Jul 24 2020, 09:31 PM
QUOTE(windforfun @ Jul 4 2020, 02:32 PM)
Panasports on my 2002.
914e
Jul 24 2020, 10:27 PM
QUOTE(Driver174 @ Jul 24 2020, 08:24 PM)
Click to view attachmentAre they offering that color as a standard option now? It looks about the same color as mine.
Driver174
Jul 25 2020, 12:42 AM
QUOTE(914e @ Jul 24 2020, 09:27 PM)
VTO offers custom powder coating, so many color choices available.
As for the lug bolts, they are 60 degree taper, not the Porsche conical seats.
Craigers17
Jul 27 2020, 06:45 PM
On the 7" wheels, I'm seeing offsets from 31 to 38mm,
@914e I wonder if you could tell me the offset on yours?
Driver174
Jul 27 2020, 11:13 PM
QUOTE(Craigers17 @ Jul 27 2020, 05:45 PM)
Actually I incorrectly stated 15 x 7 with 38 mm offset. The offset is + 36 mm. I have 1" spacers on the front wheels, and 1/8" spacers on the rear wheels.
Jim
Driver174
Jul 27 2020, 11:26 PM
mwyatt
Jul 28 2020, 01:26 PM
@Driver174 those look great. Thanks for posting their weight, sounds pretty good.
914e
Jul 28 2020, 01:44 PM
From my invoice they are 35mm I thought they were 36mm. Could be a typo. I don't think a mm makes much of difference.
