QUOTE(914_teener @ Jul 20 2020, 09:15 PM)
My advice is to mount it below and above the air diverter on the passenger fire wall. Much easier installation and easier to access. There are several threads on this going several if not more years ago.
I know Porsche changed the location to the front under the steering raxk on the late cars but I wouldn.t.locate the pump there unless you are going to replace the fuel lines in the tunnel. There are a lot more reasons in my mind to not to move it to the front but if you are planning on moving it there....plan on replacing the lines as well for one really good reason.
Edit:
See someone commented on that already....oh yea....don.t use copper...fuel corosion is only one reason not to use it.
Good luck.
I’m trying to learn (and decide) . . . what are the reasons not to relocate the fuel pump to the front? I’ve heard it said that a fuel pump should “pump not suck” and there’s the (recent) fire issue . . . yet I’d rather not cut any holes. . .
