QUOTE(CoronaMike @ Jul 7 2020, 06:39 AM)
QUOTE(Mikey914 @ Jul 7 2020, 02:47 AM)
We do ,
Thanks Cary
@mikey914 I actually just bought one of those - but it's not the same thing. That's for a 1.7 or 2.0 and it goes in a different spot. It has smaller openings. For some reason I didn't read the description when i bought it. BUT...I have one now just in case...?
What is the hose ID on the one that came out?
The elbows I received from 914 rubber fit both the early and late AARs that i have around here (along with most other hose connections on my 2.0s and 1.7s. They do have to stretch a bit to make the connection but that is necessary as it needs to be an air tight seal. Per the 1.8 hose diagram that i have all those hoses from the AAR on a 1.8 should be 13mm(which these fit) only hose I see that is larger on the 1.8 is from the Decel Valve. Are you sure your hose routing is correct?
