Fuel pressure was good at 29 psi
Checked for spark putting a plug in a wire and cranking it fires one spark only the nothing nada zip
Checked coil ohms secondary 9750 ohms; primary 4.5 ohms seems good
Battery 12V But only 11.79 V at positive terminal of coil when ignition is on
And only 10.5V when starting
Is this a bad coil? Bad relay board? Bad wiring harness?
Something else ?
What should I check next
