william1764
Jul 13 2020, 10:14 AM
Indy just replaced sending unit on my 74' 2.0 He replaced it because gauge was not registering any temp. Drove 20 hwy miles today in 80 degree weather. Oil temp never got above 150 degrees. That can't be accurate - can it?
GregAmy
Jul 13 2020, 10:23 AM
william1764
Jul 13 2020, 10:43 AM
nditiz1
Jul 13 2020, 10:46 AM
Did you match that gauge with the correct sender? If not it will not be accurate.
Also, where are you located in MD?
GregAmy
Jul 13 2020, 10:50 AM
Yeah, that's aftermarket VDO. They have specific senders for specific gauges, two different ones as I recall.
Oil temp staying at 150F is not expected, especially in summer.
william1764
Jul 13 2020, 10:54 AM
The indy said he spoke with VDO about what he needed however i'm suspect...particularly given this indy:-(
Indy is suggesting that maybe the engine didn't have chance to reach temps in 20 miles in 80 degree weather - uggh
I'll follow up with indy to verify that gauge and sender match.
GregAmy
Jul 13 2020, 12:23 PM
Give it a longer drive first. 150F may be normal after only 20 minutes. Give it a good 30-40+ and see where it stabilizes.
I have an external cooler with a 180F physical thermostat, and I measure the oil temp in the cooler lines. I'm skeptical that it takes 20 minutes, but it does take a good chunk of minutes before I start to see an oil temp indication above ambient.
william1764
Jul 13 2020, 01:06 PM
QUOTE(GregAmy @ Jul 13 2020, 10:23 AM)
Sorry. Drive was 20 miles...about 35 minutes
william1764
Jul 13 2020, 01:08 PM
QUOTE(nditiz1 @ Jul 13 2020, 08:46 AM)
They supposedly matched gauge and sender but I'm not confident indy actually did. Digging into that now.
I'm close to you...located in Woodbine.
bdstone914
Jul 13 2020, 09:49 PM
Where is the sender located?
Is the top portion exposed to airflow? That can give false low readings.
Do you have an infra red heat gun to chech the temp?
william1764
Jul 14 2020, 06:40 AM
QUOTE(bdstone914 @ Jul 13 2020, 07:49 PM)
I’ll need to check that. Ty
