I'm looking for the brake line fittings that go into the master cylinder on the end of the reservoir lines.
Eric at PMB lists the plastic lines (for about $30), but my metal fittings at the bottom are corroded and the replacement porsche ones are v expensive from Stoddards/AA/Pelican etc
Looking for a clean set of used ones, or is anyone remaking them from the correct pipe??
They look like they're not too complex and simply have a flare fitting on the end that goes into the MC?
Thanks in advance Nick
