Hi all, I'm looking for an engine air filter for my '70 1.7 liter, can't seem to find it and no place has it in stock. I had ordered a NapaGold Air Filter Part #: FIL 2011 on reading some old threads here but the quality control of those filters is garbage and moreover the top of the airbox wouldn't fit over the top of the filter. Those of you who are 1.7 owners, what do you use? It it easer to just switch to a CAI setup? Thanks all
mark04usa
Jul 14 2020, 03:21 PM
A stock 1970 1.7 has an oil bath air filter, which is a very effective filtration system. I would suggest that you stick with the setup that was designed for your car.
mark04usa
Jul 14 2020, 03:22 PM
Dbl post....
windforfun
Jul 14 2020, 03:26 PM
This really opened up the engine well.
brant
Jul 14 2020, 04:34 PM
If it’s a stock housing for a 1970
It is oil bath
Meaning oil is the filter inside the box. No paper Works well
mark04usa
Jul 14 2020, 04:43 PM
and the oil bath works much better than the setup seen above
macnichol
Jul 14 2020, 04:47 PM
QUOTE(brant @ Jul 14 2020, 04:34 PM)
It is oil bath
Ohhh I see, I was under the misconception that it was something else entirely, thank you so much.
brant
Jul 14 2020, 05:00 PM
I haven’t had one since around 2003 But they work well
I don’t remember how much the capacity is So meone on this thread will know
macnichol
Jul 14 2020, 05:13 PM
QUOTE(brant @ Jul 14 2020, 05:00 PM)
Gotcha okay, I will for sure need to ask around because the oil fill line on my airbox has worn completely away. Are there any dangers to accidentally overfilling it?
