My plan was to mate the the trans and engine together this weekend. All was going well until I installed the pilot bearing and realized that it was to thick and will require machining. Then I decided to press on and put the flywheel and clutch on for a test fit. Mounted the clutch and threw the clutch disc in only to have it not fit!!! To give you some back ground I bought most of my conversion kit from an individual on ebay, all of it was brand new and most of it seems to be RH. If you can believe this, the flywheel he sold me is a Type I VW one that will accept only a 200 mm clutch kit! Well that just ruined my weekend!!! Not sure if I can go after the guy since he misrepresented the item, there was a brand new 215mm clutch kit in the setup he sold me.
The wierd thing is that someone had gone to the expense of machining this Type I wheel to fit on an SBC??? I went ahead and mounted the trans anyways, just had to see what it lookd like!
Has anyone trid to mount there adapter plate back wards? As in putting the indentation towards the motor, this will give me the space I need for the pilot bearing clearence, but may cause clutch and starter engagement problems??
