Looking for suggestions, ideas or experience for painting and/or protecting the under side of my car.. the catch is ..that it'll only be on jack stands (and outside). So I am not expecting perfection - this car will be a driver, but of course I want to do the best I can.. oh and the budget's tight as per usual.
Ok, so I've cleaned the under side of my #1project car really well, scuffed, phospho, followed by BRUSHING ON Epoxy Primer. The underside looks really good, clean and consistent now. Using my HVLP gun for the top coat is probably not going to work 'cause I doubt the car is high enough off the ground for most of it. I was thinking of getting some spray paint cans - not necessary to get color coded cans (the expense mostly). But how many cans would it take for the entire underside? Any common spray can recommendations that might be good for this task?
Brushing on the top coat seems out of the question .. though I was surprised how well the the epoxy primer came out.. and it IS just the underside of the car, not really to be seen anyway. Ya'll think that's an option? Maybe spray can bead liner followed by spray bomb color from the FLAPS? How would you guys handle this?
