Hi All,
Hope all are staying safe in these trying times. Glad I have a 914 to play with!
I have recently realized that the oil temp gauge in the cockpit is not only likely the wrong type but I do not seem to have the sender/sensor from the taco plate. It is a VDO gauge but it isn't like the ones I have seen described or pictured here. Namely, the gauge has no red zone. I should also mention the temp gauge is an after market add as it is hanging from the center of the console.
As I mentioned, after having a look at the taco plate, there does not seem to be a sender/sensor or at least nothing that looks like what it should.
I want to know that the 914 isn't running hot so I need to replace/add so that I get a temp reading in the cockpit. At this point I assume I need a new gauge, sender/sensor, and plate that holds the sender/sensor to accomplish.
What I am having trouble with is finding the right combo of parts. I understand that the gauge will dictate which sender/sensor I need. As I am still familiarizing myself with parts and gaining confidence when I buy parts, I want to ask what gauge and sender/sensor combo do I get. Also, where can I find these parts as Pelican seems to be limited with regard to the gauge.
Thanks in advance!
