QUOTE(nathanxnathan @ Jul 20 2020, 09:36 PM)
I've seen some threads, but they just breeze through this like it's easy.
I had to drill the roll pin out. I've been soaking it with liquid wrench for days. I had it red hot with a propane torch. It seems like there's nothing to locate it in a press or to get ahold of it on the opposite side to keep it from spinning if I want to muscle it to spin it free. I resorted to trying to pound it out which made it worse, mushrooming it some. I'm getting frustrated.
You need a solid mounted vice. Spread the jaws to the width of the shaft diameter.
Place the shaft end into the gap in the vise.
Hit the other end of the shaft with a big hammer to push the shaft out farther. File down the mushroomed end.
Clamp the clutch arm end into the vise.
Use a big a adjustable wrench on the other end of the arm and twist back and forth.
Once it starts to move get a small pry bar under the lip of the arm and pry while you twist.
Or send it to me for a restored set.
