Thanks for sharing ! A righteous Porsche on it's own level...just add fresh tires, a proper Fuel-Safe bladder tank, and a good DE instructor. Nothing sounds better than straight pipes on a CGT
thelogo
Jul 26 2020, 10:42 PM
The video eludes to the weight of the car At 3100lbs. So its not exactly tossable.
Not quite sure why its so heavy . but v10 engines and huge wheels and tires will do that .
Something tells me the car isnt a widow maker that it has the reputation of being Im sure when you go twards the edge it warns you . But ignore the warning more then once and you'll be sorry And just at the most crucial time like corner exit ... You need to get those bottom pivot pedals to work perfect . I assume they are pretty sensitive . as in it takes a while to master this car
