QUOTE(aoor0708 @ Jul 27 2020, 05:29 PM)
Have recently bought a 914 - 1972 - date 12/7 - 1689 cc which is running terrible and produces a gasolie smell. Have tried to tune with the existing ECU and Pressure Unit, but no good results. Found out the ECU has a numer 0280-000-037 and the Pressure Unit 311-906-051B
Presume these unit are not correct for this engine.
Anybody could provide me with ECU and Pressure Unit numbers that fit this engine ?
Hi,
the ECU is the correct one.
Your MPS is false - meant for the VW type 3 1600 ccm.
You need the 022906051E that was installed to VW type 4 (411) and the 914.
Bosch # is 0 280 100 049, search for 0280100049 and you will find several used units.
I wish you find a unit that wasn't misadjusted and with the diaphragm not broken.
Check this when you receive the part. Follow the link Beatnavy posted. A MPS with broken diaphragm cannot work correctly.
Regards
Norbert
