Here is a pile of little bits of new parts that did not get used on my build.
$50 plus $10 shipping paypal preferred
-Oil temp sensor paper gasket
-3 bolt sealing rings for oil temp cover plate
-shift coupling bushings
-a-arm foam gaskets
-headlight adjuster blocks
-rain tubes
-4 fuel hose clamps
-1 rear bump stop
-4 fuel hose elbows for injectors
-rubber cover for ecu adjuster knob
-4 copper exhaust to head gaskets
-D-jet vacuum F fitting
-2 engine tin to heat tubes grommet
-2 rocker or valance spacers
-hood emblem gasket
-4 bumper top spacers
-oil temp wire to engine tin grommet
-2 front strut bump stops
-24 stainless allen head engine tin screws
-24" of correct blue brake fluid reservoir braided hose
