From my very recent experience I would look at, in this order:
1. Clutch disengagement adjustment - since going into Reverse is very different than 1st, could be the engine is still spinning the gears when you have the shifter in neutral and the clutch depressed.
2. Sync Rings for First - though this will explain first, it does not (to me anyway) make sense for reverse.
How many miles on the tranny? has it always done this? just started? what changed, etc......
QUOTE(cal914 @ Aug 3 2020, 02:21 PM)
I’ve got a gt replica with an original 6 engine and transmission ,when I first get her out of the garage first and reverse go into to gear easy enough but once she’s been driven a while and warms up the only way it will go into these gears is by crunching them ,I have a short shifter fitted and all the other gears are okay ,any one have any ideas
Thanks B
