QUOTE(GregAmy @ Aug 4 2020, 09:16 AM)
Try something simple: replace the fuel pump relay. You can use one from the headlights if you don't have any spares (shame on you!
If pulling the relay stops the pump, but replacing it does not, then you have a good general idea of what half the of the car to look at (focus on the control circuit).
QUOTE(Frankvw @ Aug 4 2020, 10:05 AM)
or....the power to the fuelpump does not come from the relayboard but from the battery directly, so 12V all the time. But you will know if you pull the relay.....
Since the car had pump issues before, you mention this, maybe they did a fix and got the power somewhere else as workaround or test.....
Guys, This is not D-Jet, this is L-Jet. The L-Jet system does not use the relays on the relay board. It has a separate, double relay mounted on the battery tray support. You can run an L-Jet car with NO relays in the relay board.
Clay
