QUOTE(michael7810 @ Aug 8 2020, 12:50 PM)
QUOTE(Mark Henry @ Aug 8 2020, 10:54 AM)
QUOTE(michael7810 @ Aug 8 2020, 09:08 AM)
Couple thoughts. The linkage shouldn’t be an issue if both stop screws are set properly. Even if the cross bar is affected by heat the throttle plates can’t close if the screws are set.
Wrong.
How could the linkage force the throttle plates closed when the stop screws on the carbs are set to touch the linkage at idle? Wouldn't the force need to be so much that the screws and/or the throttle plate shaft bends? Seems unlikely there would be enough force to do that.
It depends on where the linkage is installed. If the linkage is on the opposite side of the stop it is feasible to force one side of the carb past the stop thereby closing the butterfly. If you have ever worked with dual carbs and no linkage you can easily see this by force the shaft from the non stopper side. The rpm's will go down.
Upping the idle from 60 to 65 may just mask the issue if it is in fact related to an intake leak or in my case a cylinder to head leak. In order to diagnose properly you will need proper equipment. You may want to temporarily install a AFR meter to gauge if you are in fact going lean. If you are 12-13 at idle then you shouldn't need to go up an idle jet.
As someone already mentioned check your intake gaskets. These could easily be creating a lean condition if air is getting by.
Lastly, which distributor are you running and did you set the timing when the engine was warm/hot?
