No need to sit on duct tape any longer. It's not quite as easy as changing the oil, but if you've got a little patience and willing to futz a bit, you can do it. It's fun to try, anyway. And what's the worst that can happen?
Thanks, Guys. This is not as easy as changing the oil, but definitely doable with a little time and trial/error. Worst that happens is you lose patience and just send it off to the upholstery shop
dax1969
Aug 14 2020, 05:39 AM
Good job, I know where the difficulties are...
Just a tip : pull on old panty or (stretchable) sock over the headrest before you put the cover on. This way your brittle foam will stay together. Another hint is to use vaseline spray on the foam or inside the covers... slides better and leaves no stains.
looking forward to see more vids.... keep up the good work
