Full Version: 123Distributor install question.
JMT
After installing the 123Distributor and turning the body CCW until the green light turns on this is where the rotor and #1 plug wire line up at TDC. Since the rotor turns clockwise it's already passed the #1 plug wire. Does it have to be pointing exactly at #1 plug or just in the general area to start the engine?
DRPHIL914
just in general it should start, but it’s touchy and a very small amount of movement makes a huge difference, so adjust slowly, once warmed up set timing same as usual. should be good to go
Olympic 914
Timing is set BTDC (I think 5deg)
Before Top Dead Center
So you should back it up a couple degrees.
JMT
laugh.gif Lol yes retarded. However, when I back it up to line up with the #1 plug the little green light goes out.
Olympic 914
You have to put the 5 deg timing mark in the V ( or 7.5 )
it is before the 0 TDC mark
Depending on your engine and fan there should be timing marks at 27 BTDC, 5 BTDC and 0 TDC.
I think on a 1.8 the marks are at 7.5 BTDC. and 27 BTDC
Someone will correct me if I am wrong.
You could just advance it a little to get it started and then set the timing with a timing light @ 27 btdc 3000 rpm
JMT
Hey Olympic. It's a 2.0 so only 0 and 27 BTDC. That's actually what I did to start it but was curious why the rotor and #1 plug don't line up. Maybe it's a moot point since you can customize the curve with the bluetooth app.
Not_A_Six
QUOTE(JMT @ Aug 12 2020, 12:28 PM) *
You only have to line the LED up good enough for the engine to start. After that, you should rotate the distributor and set the timing with a light at whatever the appropriate advance/rpm is for your engine.
Not_A_Six
Is that D-Jet? If so, there are some nuances with the 123. Namely, choosing the right profile from the limited choices available via DIP switch, and getting the orientation/polarity correct for proper fuel injection pulse phasing:
http://www.914world.com/bbs2/index.php?act...=2&t=347291
JMT
It's a Bluetooth. I picked a curve that Mcmark suggested to someone on a thread I read here.
Not_A_Six
QUOTE(JMT @ Aug 12 2020, 07:46 PM) *
Nice! No D-Jet weirdness then. Does the bluetooth version let you set a rev limiter rpm?
JMT
It does and just about everything else.
pete000
When I did my 1.8 i just started where the green light was on then set the timing using the flywheel marks. These are great distributers. The blue tooh adjust ability is fantastic.
Invision Power Board © 2001-2024 Invision Power Services, Inc.
