Full Version: Rear Trunk Release
GAT
Have a 1973 914 that someone installed an electric rear trunk release. It was always a problem; you had to energize the solenoid by the pushbutton and while energized push down on the trunk lid. Now it does not operate at all; no sound from the solenoid when the pushbutton is depressed. Is there a way to open the rear trunk lid manually?
VegasRacer
The old ratchet + lots of extensions should do the trick. Best done with a helper.
- Pop the top latch cups and push them inside the trunk
- Have a helper shine a flashlight trough one of the cup holes onto the rear latch assembly
- Get a ratchet and add enough extensions to get you through the other cup hole all the way back to the rear latch. You may want to use a swivel extension at the end.
- Undo the two bolts that hold the latch to the rear panel
- Done
ValcoOscar
QUOTE(VegasRacer @ Aug 13 2020, 02:43 PM) *
- Done
I agree with John...but check to see if you have a blown fuse first idea.gif
Oscar
fiacra
QUOTE(ValcoOscar @ Aug 13 2020, 02:47 PM) *
- Done
Oscar
You should also check that the previous owner didn't already install a manual release cord. Can't find it immediately but this was in a previous thread along with pictures (I think) about where to locate this.
dr914@autoatlanta.com
hold the lid down while someone pushes the button to see if it will spring then if not but power directly to the wire (should find it in the engine compartment). Usually it is because the hinge pivot bolts need lubrication and or the rear catch and latch need lubrication. If the plunger is not seated into the solenoid far enough, the electromagnet will not grab it. Other than that the easiest way is to drill a very small hold in the middle of the "S" and insert a welding rod to trip the lower catch
QUOTE(GAT @ Aug 13 2020, 02:36 PM) *
Nojoah
Before you starting cutting, drilling, etc, make sure you rule out all possible other options. Check for a blown fuse as others have stated. Make sure the car is running or the key is in the accessory position. Have someone push down while you press the button. Before I removed the solenoid and converted the car back to stock mine was very finicky and often required numerous attempts. Lots of frustration and rear deck lid smacking. chair.gif chair.gif
GAT
QUOTE(VegasRacer @ Aug 13 2020, 04:43 PM) *
- Done
Thank you for the information. What size socket do I need to use?
oakdalecurtis
Here's a previous thread on the subject. You might want to check my post #5 for a long term solution...
http://www.914world.com/bbs2/index.php?sho...l=trunk+release
VegasRacer
QUOTE(GAT @ Aug 19 2020, 11:00 AM) *
10 mm
