QUOTE(porschetub @ Aug 15 2020, 05:14 PM)
QUOTE(Mark Henry @ Aug 15 2020, 11:10 PM)
It has to be in a straight line, so if you want to keep the clamp I'd put it between the factory clamp and cooler, catching some of the barb with the factory clamp but leaving enough room to safely install the supplied ABA clamp.
You lose 1-1/2" off the hose for the valve body, but add in the barbs and you have the equivalent of adding about 4" of solid pipe to the hose.
Torque the ABA clamps to 35 inch pounds
Please post a pic of your install in my review thread.
Mark did you use the 2.7 on (?) push on type hose ,the soft rubber one ?.
Click to view attachmentDid you fit a hose tail of the tank for this fitment ?.
Thanks.
Yes, commonly called a 911 "S hose".
If you read the tread in the link I stated I made custom adapters. The down hose I made but is basically a stock cohline hose/fittings, the rest I made including the one inch 90 NPT elbow I TIG welded to the cooler.
Compared to what I did the OP install is dead simple.
The only reason I suggested catching part of the factory /6 clamp, which just holds the hose up, is for if the total length of the valve is an issue. You still have to use the supplied ABA clamps.
QUOTE(rudedude @ Aug 15 2020, 11:15 AM)
You can make your own oil lines using your existing fittings and Stoddard has the original cohline oil line
Why?
..and why over complicate things?
