Custom gauges in factory 60mm cans. Will plug in factory harness except you will have to run a wire to the oil double pole sender for temp or pressure depending on how you do it. Eliminates the clock but gives you full engine information. New outer rings, fully tested by North Hollywood. Face plate included but you will have to replace back clips. Cost over $350 to build.
$199 shipped.
PP:
