QUOTE(Ebradley @ Aug 17 2020, 04:31 PM)
Hi
I’ve owned my 74 Porsche 2.0 for four months now. I’m 3rd owner and has 100k original miles. Yesterday, I drove it to grab take out food and it was 100degrees outside. After I parked and grabbed food, wouldn’t start. Eventually started then stalled a few times as I pulled up to a traffic stoplight. Any ideas? Vapor lock? Thanks
Did the fuel pump get re-located up front? If not, you probably have vapor lock.
It is almost mandatory to move it up front if you live in Texas and want to actually use the car in the summer.
If you relocate the pump, I would also suggest that you put in a set of stainless steel fuel lines from Tangerine racing. The plastic lines are almost 50 years old now, and are getting brittle from engine compartment heat. Better safe than on fire.
Clay
