Full Version: Rotor Compatibility
frostyf
Wondered if anyone knows whether the VW 411 Rotors are compatible or straight swap onto a stock 4 stud 2.0l 1973 914??
Found a zimmerman set of front rotors with same part number at a great price (well $20 less each than I can find from some of the larger suppliers) and I wondered if anyone knows are these the same or are there likely to be compatibility issues.
Part being advertised is for a Type 4 411/412 Part Reference Number: 411407075
914Sixer
Need to be 075A to use on a 73-76.
frostyf
QUOTE(914Sixer @ Aug 25 2020, 12:53 AM) *
Thanks for the info! What different types are there, do you know?
porschetub
QUOTE(frostyf @ Aug 25 2020, 01:15 PM) *
Most likely the offset is different,the 411 and 412 were weird cars but fairly sure they used late T3 brakes.
914Sixer
Offset difference for caliper and centering hub are hat the changes were.
