Ive been restoring/modifying my 74 914 for the last 6-7 months. I built wooden car stands which sat atop wheel dollies which in turn suspended my 914 from its 4 jack points and allowed for mobility within my garage. The entire car has been gone through except for the dash removal and engine removal. The restoration was done working around the dash in place. Harness was wound, placed in a plastic bag and taped shut to seal it from debris. The engine compartment was pretty much untouched... except for removal of engine cover, mesh, firewall insulation (re-welded engine cover tabs). Engine compartment will be refinished come winter while the engine is out for rebuild (2270). Trailing arms, all suspension, axle shafts, steering rack, were all removed to sand/blast/paint and reinstall with new bushings (converted to 5 lug with 911, 944, and 986 parts).
So, there is the small back story to the car (in case any of that sets off a flag for my issues). Im the second owner and have not had any issues (other than burning oil - leaky valve cover gaskets, push rod o-rings). The engine is a 1.8 with dual Weber 40 IDFs. It made the trek from Kentucky to St Louis when I bought it about a yr ago with no issues... other than some heavy smoke at stoplights from oil leaking on the heat exchangers. Once back here, it was only driven maybe 300-350 miles before being put up on stands for resto.
Yesterday, I got the car down and wanted to get a couple miles on the car to settle the suspension before taking it in for alignment.
When I got the battery of the trickle charger and got it installed, everything powered up and worked beautifully... All lighting, horn, signals, cigarette lighter, door buzzer, etc. The car would not start. My fuel pump hums, relays click... Checked power at the starter red wire and Im good. Yellow Solenoid has no current. Traced back to the seatbelt relay under the passenger seat. Solid yellow (pin C - on the bottom) which i assume comes from the ignition is hot. Yellow/Red (pin 50 - on top) which runs to the board in the engine compartment is not. Had my daughter "Start" the car and hold the ignition in the "Start" position for current load, No power. Tried bypassing the relay by jumping C and 50 to no avail. In the meantime we could smell a strong electrical burning. Come to notice the distributor smoking. Pulled the cap and the + from the coil. Went back to troubleshooting my non-start only to notice the distributor smoking again. The black - wire was hot. This was happening while my daughter was holding the key in the "Start" position.
At that point i was done for the night... Frustrated I could not get my shakedown in after being up on the stands for 7 months and finding the car wont start and seems to be shorting my points.
Never had an issue like this in the past. Im not sure what distributor is on the car. There is no vac advance as the PO removed the original and installed this one when he installed the Webers (if my memory serves me correctly)
Any ideas why/what could prevent the starter solenoid from getting power even when jumping the two pins? (the harness between the dash was not touched (except to remove gauges to paint the gauge surround) The harness was left in the tunnel and masking tape placed over to protect it. That bit of the passenger compartment under the harness did not get stripped or painted. The bits from under the passenger and driver seat were rolled up, sealed and a plastic bag and taped shut. The bag was suspended with a string during paint. The harness in the engine compartment was never touched, though the rear trunk harness was wound up, bagged and put in the engine compartment during paint.
I told myself I was going to walk away from the car today... but I just have this nagging issue that I cant leave alone until I know its resolved.
Thanks in advance
