After sitting in heavy rain (this is the UK after all...) my car almost always has water sitting on the inner door seal in the same place, roughly adjacent to the front of the seat(s) – ie, about midway between the seat strengthener on the floor and the front 'corner' of the door opening. The door seals, both inner and outer, are all new from 914rubber. The consequence of this is that the water is absorbed by the sill carpet and then tracks down under the floor mat.
What I have discovered is that when you squeeze the seal, a fair amount of water is pushed out – the neoprene seal, instead of sealing against the door and physically preventing water getting by, appears to be soaking it up and allowing it to track into the car. Does anyone else have this problem? Or any observations? Having just had the rear floor repaired and a whole new carpet set installed, I'm keen to eliminate the leaks.
Was the original factory seal neoprene or rubber (sadly I threw the original away when I replaced the seals... doh!)?
