QUOTE(infraredcalvin @ Sep 1 2020, 10:08 AM)
https://www.paragon-products.com/Lowering-S...914_springs.htmWhat you have is a 100# replacement street springs. These are pretty typical spring rates for a slightly stiffer ride. I'm surprised you think they are too stiff. The KYBs on the other hand have a reputation for being junk, lovingly referred to as Kill Your Back shocks. I've been lucky enough never to have owned any KYBs, so I'm only referencing what I've read.
I had them(KYB). They do suck. Either use some Bil's or find a nice set of used Boge's. They are what came on most oem and probably have the smoothest ride. AA is advertising a reproduction Boge that's sold new but I don't know if it's out to market yet.
What I do know is getting rid of the KYB's with transform your car for the better. Also, a lot of what we tend to attribute to the rear shocks is from the front. Make sure they are decent as well. Our cars are light and can often run lower tire pressures than current cars. Most 914's have wider than stock tires, so it's fine to play around a bit to see what works for you.
Used KYB's don't generally have any value for resale other than to hold a roller up off the ground.
