QUOTE(7TPorsh @ Sep 3 2020, 08:01 AM)
This is a new 2366 SCAT. The same area on the original 1.7 block is shut. I have no idea what this is. If I had to guess it's some performance thing.
What is this? Is there a fitting? DO I seal it?
The orange one is the cooling fan housing the blows air through the heat exchangers, should be one on the other side as well.
The hole in the block itself is an enormous oil leak. NOT a performance thing, looks like they used a bus case. That is were the bus oil filler attaches, you will need a blockoff plate.
+1 on a buss case. I got the same on the engine I now have despite having sent a 914 case to the engine builder. I sent the engine back and told them to use my case.
