Hello Suspension experts. Looking to swap out my stock rear springs. Seeing as I have an LS6 I was thinking the 180 or 200 pound springs would be good?
I just purchased some new koni shocks,
thoughts, comments, concerns always welcomed
thank you
Literati914
Sep 9 2020, 08:26 AM
I THINK the 180 - 200 is light for a V8, but do some research. I have a set of Carrera brand 260 lb. springs, they're 2.5" ID x 10"L $55 shipped (F&F).
ri914
Sep 10 2020, 06:45 AM
QUOTE(Literati914 @ Sep 9 2020, 10:26 AM)
thank you for the offer Literati. I have some more homework to do before I buy anything. Those springs look like a great deal, just need to figure out my front torsion specs and the ride height for the rear.
Mikey914
Sep 10 2020, 10:04 AM
With the LS the 200# spring should be in the ballpark.
You will want to measure your flange plates to check fit if you use the 2.5 ID springs.
Sorry we only make the 140/160 progressive, it may be a bit light for your application if you are really getting on it. @matty900 Are you using the 140/160's on your set up?
Chris914n6
Sep 10 2020, 01:34 PM
Renegade Hybrids has 200 lbs springs in 914 diameter.
Matty900
Sep 10 2020, 04:36 PM
With an LS and an aluminum block, you are not enough off from the original engine that you would need that much more spring is my understanding. I installed the 914 Rubber 140 lb progressive springs but my car is at the body shop currently so I have no road time on them yet. I will however be heading to Renegade a week from Monday to plan out the rest of my build and I can report back then.
