Tdskip
Sep 14 2020, 12:42 PM
Hi folks-working on the white Fresno car and it looks like it needs a new clutch cable.
The engine is currently out so it seems worth asking, because I’ve not done this before, if it makes a big difference to replace it with the engine in or out?
I’ve already replaced the brake lines and installed new transmission mounts, so the engine is otherwise ready to go back in, but if it makes sense to wait until the clutch cable is replaced now would be the time to make that decision.
Thanks!
JamesM
Sep 14 2020, 12:53 PM
I would wait until after you put the engine back in so the new clutch cable is not in your way and at risk of getting damaged
Tdskip
Sep 14 2020, 01:21 PM
QUOTE(JamesM @ Sep 14 2020, 01:53 PM)
Good tip - thanks for the fast response!
burton73
Sep 14 2020, 01:28 PM
Tom,
I would change the rear seal at this time. Part is cheap and that is good insurance
Bob B
solex
Sep 14 2020, 01:35 PM
I just replaced the clutch cable this weekend and agree with others that the only reason to wait until the engine is in is so it is not in your way.
The only hard part is at the pedal, but it is not really that hard just remember that the threaded rod at the clevis should have a 10 mm reveal and make sure you get a cable with the Teflon sleeve that goes through the tube in the tunnel. The Teflon makes a world of difference.
Also if you are contemplating replacing the accelerator cable, make sure you run a screw driver or something similar through the tube at the firewall to clear any debris or kinks in the tube this is much easier to do with the engine out.
Tdskip
Sep 14 2020, 02:06 PM
Good stuff. thanks for the reply. Very helpful gentlemen, much appreciated.
