Tdskip
Sep 14 2020, 04:50 PM
Working on that white Fresno car and I have two rebuilt CV/axles but one has pins, two per side, and the other does not.
I have two spare (needig servicng) that have dowels - can I just lmoves the dowels over to the ready to use ones?
Thanks, cranking to try to get this done and I really appreciate everybody’s help!
(I did try searching first)
914werke
Sep 14 2020, 05:49 PM
Perhaps.
The issue I alluded to in another thread is that since 914 CV's are NLA it is typical to use T1 CV's in their place. BUT while dimension are similar, they are not the same.
If that is what you have, the roll pins, dowels, spring pins (whatever) will not fit in the T1 CV without machining. Another giveaway is the T1 CV's will not have a recess machined for the use of a gasket.
Superhawk996
Sep 14 2020, 05:52 PM
To further the response above.
Yes they are required.
The prevent the two parts from moving relative to one another in shear. It would take way more clamp load then the four fasteners could provide to keep the surfaces from moving relative to one another under load.
914werke
Sep 14 2020, 06:30 PM
Tdskip
Sep 14 2020, 06:45 PM
Thank you very much for the responses, I will do some checking, I think they’re 914 but if so they’ve been messed with and, well, you know how that goes.
Tdskip
Sep 14 2020, 07:16 PM
Just to follow on here and be more explicit, should I assume if any of the axles do not have the dowels/alignment pins that they are probably not 914?
Rob-O
Sep 14 2020, 08:17 PM
QUOTE(Tdskip @ Sep 14 2020, 05:16 PM)
Not necessarily. If I remember correctly the -6 CV’s have six bolts and no pins.
Mark Henry
Sep 15 2020, 04:29 AM
QUOTE(Rob-O @ Sep 14 2020, 10:17 PM)
For a /6 it depends on the year of the stubs, mine have the early 70's big CV's that have pins and M10 bolts, later are just six M10 bolts.
VW CV's are six bolt, for 4 bolt 914 you can use VW T1 cv's, IIRC you have to enlarge two holes slightly to accept the pins.
Tdskip
Sep 15 2020, 06:47 AM
Thanks for the information.
So with the VW ones “just” find the alignment pin size and take a drilll to open up two hole we’re the bolts would have gone?
Anywhere special to get the alignment pins?
Tdskip
Sep 15 2020, 10:37 AM
Does this picture show the groove that the gasket sits in there by making this a 914/6 axle/CV?
Tdskip
Sep 16 2020, 07:23 AM
Good morning. So I cleaned the various sets of these axles that I had laying around in preparation for rebuilding them.
I was able to confirm that this ring on the outside match is the known to be 914 CV joint/axles and the length is identical.
So that seems to confirm that these are 914/6 axles? Any advantage to using these on a/six build or are the equivalent in strength to the four-cylinder 914 ones? To use the 6 foot ones I need a matching six bolt flange installed under the transmission I believe, yes?
Rob-O
Sep 16 2020, 07:33 AM
A more definitive way to confirm would be to count the splines on the driveshaft/CV. I don’t remember off hand what the spline counts were but somebody here will chime in or Google is your friend.
I want to say 31 splines for the -6 and 36 splines for the -4. But that’s a WAG.
Mark Henry
Sep 16 2020, 08:02 AM
QUOTE(Tdskip @ Sep 16 2020, 09:23 AM)
There isn't a strength advantage 914/6 vs 914/4 axles. You would only get stronger axles by doing something like a 5 bolt conversion and using the 108mm hubs, stubs, CV's and Sway-A-Way axles.
I agree with Rob-O count the splines and do a search. Eric has a good write up on the different kit you can use with a 5-bolt conversion.
Tdskip
Sep 16 2020, 03:13 PM
I will get counting, thanks gentlemen.
