Good morning - I don't have that panel but if you end up ordering a new one I need the same piece and maybe we could split the shipping cost.
Is this the one you are looking for?
http://www.autoatlanta.com/results.php?par...r=914%201970-76Lower And Upper 914 Inner Wheel House (one Piece); Right; 914 1...
91450194420C
At last, a solution to right frame rail rust. The inner rocker solves the problem from the jack post to the front, but what about under the jack post to the rear? The solution is our right inner wheel house repair panel. It solves both right rear frame rot as well as the behind the battery tray rust-through. Easily welded in, it restores these areas' strength, as well as the stock appearance. One piece does it all! Piece is made extra strong and coated for good rust protection.
