QUOTE(framos914 @ Sep 24 2020, 09:55 PM)
What year? With a good wiring diagram, check why the coil on flasher relay is always getting power and activating. Work your way back to the source. The diagram will tell what to expect on each pin of relay.
If the coil is stuck closed the lights will operate normal when you pull the switch.
It's a 74 2.0L. I have one of those enlarged color wire diagrams. My eyes can't read those crapy Haynes diagrams.
