QUOTE(Mikey914 @ Oct 24 2020, 11:41 AM)
Normal maybe. Factory correct no. The diagram at the top of the page shows the correct routing less the extra star in red.
If you look closely it should go to the decel valve. There is usually some creative plumbing to "fix" a problem. Are you running a stock FI setup?
As far as I know I am. I ordered the part this morning so when I get it I will see if I can get it back to the original configuration, or if it acts odd, I'll know that there was some reason to do this. Thank you for your input!
