I have a small-red-scale combo temp gauge 914 641 101 50 - I've modified a couple of things including adding an LED indicator in the previously dead space and LED lighting.
Wondering about numbering the temp scale.
Someone check my math - according to https://bowlsby.net/914/Classic/zTN_Elect_OilTempGauge2.jpg - this confirms the calibration markings on mine: 30 on the bottom line, 156.7 at the bottom of the red scale and 170 at the mid point of the red.
So - extrapolating from that:
30c and 170c at the top
That's a 140c swing - so that puts it 100c in the center with 65c at the 1/4 mark and 135 at the 3/4 mark - right?
Converting to F:
+/- 85 on the bottom, 150f at 1/4, 210 at 1/2, 275 at 3/4 and 335 at the top - right?
Like this:
This is assuming 200c sender and jives with the Bowlsby.net info.
I reached out to https://www.heiler-tachodesign.de and they responded with the mock-up - but I was just sort of throwing numbers out there - but I think I'm close with this?
Suggestions? Should I leave the bottom "85" off as it's basically meaningless or should I leave it for symmetry?
Or....am I way off here?!
