QUOTE(914werke @ Nov 2 2020, 02:05 PM)
QUOTE(rothaus @ Nov 2 2020, 09:31 AM)
The rings for the 3 main gauges holding mechanically, and can be removed if needed.
Can you elaborate?
Do I pry off & replace or do they snap over my existing OE rings?
Here from the instructions:
After removing the new rings from the package, try each ring on the gauge rings for fitment.
At this point they will be loose. Remove the rings and go to next step.
Next: Use a small screw driver to roll the edge of the trim ring slightly so a hook will be created. Do this for all the way around the edge. See picture.
Click to view attachmentBe careful and just do it very light and test fit. If it’s still lose and will not click in, repeat it until the ring clicks in and sits firm.
Thanks
Engelbert
