The RD inner wheelhouse repair piece has a second layer on the inside. I've seen
rust repair progress pics that seem to show that circular hole which is cut in the
inside layer, presumably on the original factory piece if they're just starting the repair.
Question is:
* Is the second layer only in the aftermarket repair piece?
* Was the second layer always used by factory?
* or Was the second layer used only in certain years or a running change?
This is not to be confused with the inner long engine compartment which we
know has an outer smooth layer and an inner corrugated layer.
Thanks
