QUOTE(Chris914n6 @ Oct 3 2020, 04:25 PM)
Best solution is put the stock calipers back on....
If this is a street driven car stock brakes will be fine unless you've done big HP upgrades and/or added large sticky tires like and Autocross or Track tire.
Tire grip has the largest determination upon braking distances not the type of brake caliper. 2nd up from that would be the brake pad friction determined by the pad compounding itself.
Also the steel wheel setup will run hotter brake temperatures than an aluminum wheel that offers more airflow cooling to the rotor and the thermal mass effect of having a nice big aluminum mass attached to it to suck heat out of the rotors.
Not trying to disuade you if you know what you want and why you want it. Just laying out food for thought.
