Hi all -
I have a Boxster S 6-speed (G86-20) and I'm running a Tilton pedal assy. I currently have a 7/8" bore clutch master cyl (Tilton model 76) pushing the stock Boxster slave cyl.
The clutch is really abrupt. Great on track, not so great on the street.
So, which size bore are you using? And are you running the stock pedal assy or after maket?
I understand, though haven't confirmed, the stock master is 19mm. What I can't assume is the pedal stroke / activation geometry is equivalent between stock and the Tiltons. I suppose I can grab a stock pedal set and work it out, but I thought I'd check to see what others have done.
I talked with Tilton and I'm thinking I'll try the 3/4" or maybe even their 7/10".
Thanks in advance for any help.
