On a '74 2.0 with original D Jet-
Since my last post, got the Bowlsby rebuilt MPS in and although a bit hard to start cold the car is running better. Auxiliary Air is still blocked off, as is cold start. New TPS. Although the Aux Air seems to close, I want to do some more testing on it.
Now it seems I cannot get the idle to fall below about 11-1200 rpm. In fact, it will run with the throttle body airscrew all the way in.
Am I correct in assuming that it has to be a vacuum leak somewhere allowing air in?
I've been through virtually everything checking for leaks except the throttle body itself and the plenum. Probably the issue?
Thanks-
