Str1974
Oct 13 2020, 12:43 PM
I have a 74' 1.8 L and am thinking about replacing the old rusted heat exchangers on it. Since the 2.0 L heat exchangers fit the 1.8 (I have been told?) but then require a different set up with the exhaust system. Since this is the case, I guess I would need to get a muffler/exhaust that fits to the SSI Hat Exchangers that I am thinking of getting. I see various exhausts out there, but would like some real world recommendations for a SS exhaust. I am leaning to one that has the single or duel center set up, as long as it clears my existing valence (driver side indent). If there are too many problems, and/or mods required to the valence to have "center" pipes, I will have to settle with the single driver's side tip. Any opinions anyone willing to share????
jaredmcginness
Oct 13 2020, 01:02 PM
Contact
@mepstein He has some 2.0 Stainless mufflers in stock. Totally beautiful and a really fair price for the quality.
Check out some info here:
http://www.914world.com/bbs2/index.php?showtopic=347735
FJ1200
Oct 13 2020, 01:22 PM
If you are interested, I have a clean set of 1.7/1.8 SSI heat exchangers I was planning on listing on the FS/WTB forums this weekend. I can forward pictures tomorrow. Pricing would be very realistic.
Dan
bdstone914
Oct 13 2020, 02:08 PM
QUOTE(FJ1200 @ Oct 13 2020, 12:22 PM)
Dan
1.7 and 1.8 are not the same. The 74 1.8 have larger tubes. Not a good fit to put 1.7 in a 1.8.
Rikyrat
Oct 13 2020, 02:28 PM
I have a set of 74 1.8 heat exchangers that are ceramic coated that I would let go for a reasonable price. The coating itself was almost 300.00.
PM me if you are interested.
Mark Henry
Oct 13 2020, 03:06 PM
Since you're doing both the muffler and heat exchangers you can use all 2.0 gear if you get a 2.0 muffler bracket.
Nothing wrong with the 1.8 SSI, same size tube as the 2.0, just the 2.0 has more muffler choices.
Oct 13 2020, 03:40 PM
Yes, I have 2.0 stainless steel in two out or single side out and will have 1.7/1.8 single side coming any day now. Same price for either size but 1.7/1.8 stainless heat exchangers are often hundreds less than the 2.0 version and as Mark said, ID is the same.
Str1974
Oct 15 2020, 10:07 AM
QUOTE(Rikyrat @ Oct 13 2020, 03:28 PM)
thanks, but I wanted to also reduce weight through the stainless steel set up. I appreciate the offer.
Str1974
Oct 15 2020, 10:09 AM
QUOTE(Mark Henry @ Oct 13 2020, 04:06 PM)
that's what I heard, thanks. Also like the idea of having a 2.0 setup for future engine swap.
914werke
Oct 15 2020, 12:01 PM
QUOTE(Str1974 @ Oct 15 2020, 09:07 AM)
Then I also offer a custom muffler hanger for the 2.0L that both wieghs less provided more cooling (to the muffler) and has more
STYLE! HERE
Str1974
Oct 19 2020, 10:30 AM
QUOTE(914werke @ Oct 15 2020, 01:01 PM)
STYLE! HERE That one looks pretty cool, but I bought the GT style exhaust and it requires a custom bracket (which I got with it). But, thanks anyway. I'll check out your store for other goodies.
