QUOTE(Mark Henry @ Oct 14 2020, 06:40 AM)
Ian is going to need some injectors for an SDS install. This will be based on a 2.0 Djet intake so he'd rather not mess with fuel rails, so they have to clamp in like stock injectors.
Pretty sure there was a thread that used MB or Volvo injectors that were close to the 2.0 green injectors? Low or high impedance, doesn't matter, I can add a resistor pack.
Engine 2056cc, stock 2.0 other than KB 96mm P&C's and Web 73 FI cam.
Thanks
If SDS can run with high impedance injectors take a look at these:
https://www.fiveomotorsport.com/a280-a380-h...-fuel-injector/I usually prefer these when going aftermarket ECUs with the stock intake runners.
No resistors needed, better electrical connectors, better atomization/higher pressure. Does require a different pressure regulator (though that is pretty easy to come by) Plus they come with a full datasheet and voltage/response time map so there is no guessing with aftermarket injection.
