QUOTE(Al Meredith @ Oct 14 2020, 12:51 PM)
Before you and your mechanic remove the filter or the oil cooler change the oil pressure switch. They get hot and the plastic cracks with age allowing the switch to leak. Been there AL
Great advice.....easy to check.
The oil cooler seals...not so easy. Having done those with the engine in the car....I'd yank the engine if I had to do it again.
And if you have the engine out....slippery slope...might as well do the galley plugs, and the clutch if it looks worn....that too.
Otherwise, get a drip pan.
The HE's... the early SS IIRC used CS tubes and SS shells. Later they used SS tubes which had a tendency to stress relieve and crack at the tubes and then at the ears used to mount the HE's . These should be inspected every year for that. Don't depend on some "mechanic" to do this....be my advice.
