Porsche 914-201-147-10 which is the fiber gasket for the outgoing fuel pipe that attaches to the bottom of the tank. It shows NLA, Pelican doesn't have an alternative. Don't think there is anything that special about it, but wanted to ask where you guys like to source a replacement to prevent leaks.
On a carbed car where the return fuel line will not be used any tips on how to like to block that line on the tank so it doesn't leak? Seems like better to block it at the tank rather than on the return line at the rear of the car so no fuel is in the return line.
I'll be using a low pressure pump and have not has issues with this pump needing a return line.
Thanks (and early good morning).
