Lots of people have been seeing my progress with Sumebore testing and development on Facebook. If you want to follow along, I make frequent posts on the Raby's Aircooled Technology FB page.
Porsche first used SUMEbore with the 918 Spyder, providing added durability over Alusil and Lokasil. The SUMEbore coating is applied only .004” thick, just like Nikasil. However, it is applied using a high temperature spray on process that fuses the coating to the aluminum bore in a process that is much more environmentally friendly than plating.
These coatings has excellent heat transfer, avoiding the pitfalls of iron sleeves, and offers reduced drag, improving efficiency. Iron is alloyed with other compounds, including ceramics, providing excellent durability over traditional steel liners. Another big difference is that SUMEbore coated cylinders do not receive a crosshatch during honing. They are honed to a mirror finish. Crosshatch is not required for oil retention as the coating has microscopic pores that hold oil.
Other manufacturers similarly have used SUMEbore and other APS and PTWA cylinder bore coatings on their aluminum engine blocks for high performance engines, like those found in the Nissan GT-R and Ford Shelby GT500, in place of Nikasil coatings, so we figured why not try it on an Aircooled engine?
We currently have a 1999 Boxster with a 3.2 engine built to 3.8 using SUMEbore on the road and are excited to be testing SUMEbore coated Nickies the current engine I have pictured here, which is ready for the dyno for round 1 of testing.
If you want to learn more about this family of cylinder coatings, check out this article from the AERA on mirror bore coatings:
http://www.engineprofessional.com/articles..._Tvvo_vpims_jjs
How we are using the T4 to advance this development:
I re- purposed an old 914 2.0 SCCA engine that we’ve had laying around to use as the test bed for the first “Sumebore” cylinder test engine.
In these tests we are comparing proven Nikisil cylinder plating to that of Sumebore to compare directly back to back. In round one I have built the test engine 1/2 Sumebore and 1/2 Nikisil and have optimized piston ring packs, ring gaps, and ring tensions. In round 2 and 3 we will compare output, data log blowby, log CHT and perform used oil analysis for wear metals, fuel intrusion, and viscosity loss.
This is a joint effort between Raby’s Aircooled Technology, LN Engineering, and Total Seal Piston rings to advance cylinder technology well into the future without fear of environmental challenges limiting engine longevity and power output. Nikisil is well proven, but requires acids and other hazardous materials to be performed correctly. In the future we believe this will make a big impact on all aircooled Porsche engines, including those that had factory Nikisil cylinders. We are performing this work at least a decade before we “have” to... Put simply, using Sumebore with this old 914 engine is a way that we’ve made some history.
We already have water cooled Porsche M9X engines using Sumebore, so using the simplicity of the aircooled engine made sense for this direct comparison. The T4 allows changes to be made in a fraction of time that the watercooled engine requires. Between components being made, and some practices being put in place, we can perform a cylinder change on the dyno in less than 45 minutes. Note there’s no sealant on the cylinders, and that the engine uses a Teflon buttons instead of piston pin clips.
All of this makes things happen fast, for one factor at a time practical application testing to be done. This has been a huge endeavor, with a budget that is shocking. It’s nice to have the support of the Oak Ridge National Laboratories as another tool in the toolbox making this happen.
Everything with this is about consistency, and being able to make fast changes to the cylinders, or even a fast internal repair should something fail during endurance testing. The choice of sealant, specs and etc are all major considerations. We even used the same bore size with this T4 as we have the water-cooled Sumebore engine, and also retained the same ring tensions and ring packs. The test engine ends up as a 71x101.6 just over 2.3L, and will make a solid 190HP over a period of weeks while being punished. All the parts here are used, except the cylinders, position rings and etc. This is a true "Mule motor" that will have the snot beat out of it.
The choice of cooling system is also for ease and speed when changing cylinders. I can remove one strap on the OTT and leave the fan in place. The drive can also stay in place, and the upper plenums popped off.. I can have the cylinder head off in less than 7 minutes, cylinder off in 3 minutes, and parts swapped and back together in less than 30 minutes.
When people ask me "are you still building, and developing 914 engines?" I just have to laugh.. Hell, the biggest developments to hit the Porsche aftermarket in the last 20 years are being tested right now, and I am using a 914 engine to do it! We have already learned a ton!
Click to view attachmentClick to view attachment
